2100: detection error on HDD
It failed to start just bring word2100: detection error on HDD
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
@fik87924 that is the error that comes up when your computer's BIOS is trying to access the drive and it can't. Could be related to a bad connection between the drive and the motherboard, or it could be a bad drive. I would remove the drive and then reseat it. Give it a try. If that does not work, you may have to consider a new drive.
You can download the hardware maintenance guide for the computer you listed, from here I will help you to work on your Lenovo.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 348
