Ir para o conteúdo principal
Why is my Samsung a31 vibration not working
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@zinabutenna fierst you want to make sure that it is set to work in your settings. DO a reset on your software and see if that resolves it.
If that does not fix it, follow the Samsung Flowchart
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
zinabu tenna será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 164
