Ir para o conteúdo principal
The ASUS ZenPad 3S 10 is a 9.7-inch tablet in the ZenPad line released by ASUS in October 2015. Model: P027.
20 Perguntas Visualizar todos
I need a new battery with kit to open the tablet
Hi
I have this old tablet Z500M called zenpad 3s 10. It become very slow and hanging so I think if I replaced the battery it will work better ? but I also can not find where I can buy this old battery ?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @martintomas
Search online for C12P1601 battery for suppliers of the battery that suit you best.
Usually the battery model number is printed on the battery if you wish to verify that it is the correct one.
A quick search online shows that it is not cheap
Update (09/23/23)
@martintomas
I looked for an Asus Z500M battery and found this supplier.
Then I clicked on the image of the battery in the link to enlarge it and on the battery you can see the battery model number i.e. C12P1601 and the Asus part number for the battery.
Then I searched for the battery model number
(click on image)
Alternatively you can also search for the Asus part number 0B200-02110000 (examples only)
The same battery can be used in different devices/models. It happens frequently with devices/models made by the same manufacturer
Esta resposta foi útil?
Pontuação 2
2 comentários:
I searched now it cost around $35 but this for Z500K that is different model for different regions mine is Z500M
por
how you found the battery model C12P1601 ?
por
Adicionar a sua resposta
Martin Tomas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 255
