Ir para o conteúdo principal
Repair and troubleshooting information for the HP EliteBook 840 G5, an HP laptop part of the HP EliteBook series. Released in February 2018.
20 Perguntas Visualizar todos
Laptop not turning on
when click on power ON button then on keyboard only caps lock button light blinking continuously.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @sujit72617
What colour is the Caps Lock button and how many times does it blink?
Usually it is not a continuous blink but a pattern of blinks that are repeated after a small pause between each set.
The blinks are an error code that tells you what's wrong.
Here's a link that will help you to find out what the problem may be.
Click on the Identify the Notebook Light or Beep code link on the page.
Here's the hardware maintenance manual for the laptop that will help if you need to open the laptop and check/replace any components.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sujit será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 27
Duração total: 441
