Ir para o conteúdo principal
A frequent restarting-problem
For some reason my device keeps restarting itself out of 'errors' over 5 times a day!!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@rowanmahrous the attached image is a bit (a lot) to small to be of any value :-). Check the Windows event viewer to see what it tells you. Post some pictures of what the event viewer is showing. We might be able to assist you further with this.
To get to your event viewer you will have to:
Launch the Run dialog box by simultaneously pressing the Windows key and the R key from your keyboard
In the newly launched Run windows, type in eventvwr
Hit Enter to run the command
or you can also Click Start ==> Control Panel ==> System and Security ==> Administrative Tools Here you need to double-click Event Viewer
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Rowan Mahrous será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 25
