Ir para o conteúdo principal
a budget friendly smartphone. identifiable by SM-M105F / SM-M105G.
Phone display is broken
Display fully damaged
Esta é uma boa pergunta?
Pontuação 4
4 comentários
@karanveer75985 We do not understand your question. Please open a new question, try to translate in english and give us far more information.
por
لا تعمل كارت سيم الثانية والموتر ميموار
por
Non pas trouver cart sim et cart mimoire
por
Do not work touch or touch automatic work
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi @kartikulli
Here's a video that shows how to replace the display in the phone.
Search online for GH82-18685A GH82-19366A to find display suppliers that suit you best.
Esta resposta foi útil?
Pontuação 1
4 comentários:
display fully damage
por
@vinothkuma26147 if your screen is broken, then you'll need to replace it. See @jayeff's answer for a video and part numbers needed to do the job yourself.
If there's something else you need to know, you'll have to ask; we can't read your mind.
por
Ekranına dokunulmuyor
por
@ozcan57515 if your Touch does not work, you will still have to replace the display assembly. The touch screen is part of the display assembly.
Translate
@ozcan57515 Dokunmatiğiniz çalışmazsa, yine de ekran aksamını değiştirmeniz gerekecektir. Dokunmatik ekran, ekran aksamının bir parçasıdır
por
Adicionar a sua resposta
Kartik Ulli será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 649
