Display vertical and horizontal lining issue
Display lining issue no clear picture what is problem
Esta é uma boa pergunta?
Pontuação
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 127
@ratishulvekar post a picture of what your screen shows you, with your question. We need to see what you see Adicionar imagens a uma pergunta já existente
por oldturkey03
To add to the above, we need a picture of the issue but if its really thin, maybe single pixel wide, lines that are (from what I've seen personally) usually green, red, or black - its likely that strip of pixels failing or physical damage. Which isn't often repairable without replacement of the LCD screen itself as far as I know, unfortunately.
Can't help diagnose without a picture though.
por SparkWorx
I have the same horizontal line issue
por Chandru Prakash
