Ir para o conteúdo principal
Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
black screen but game sound
when i turn it on the screen turns black with the startup sound and then game sound playing while still black. cant play
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If the screen is completely blank as a black color (from what it seems like), it is very likely you have a damaged panel or ribbon cable on the LCD.
If it's not those, your motherboard may be faulty (considering these GBAs are about 20 years old) so you either might want to look into replacing the LCD (especially if you want to install an IPS mod kit for a backlit, clear picture) or to replace the motherboard or console if the problem persists.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Patruce Lanus será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 125
