Ir para o conteúdo principal
LG's mid-Tier entry (21.5) monitor, Released in 2021.
Vertical line started blinking every 7 seconds
Apologies for selecting the wrong LG monitor model.
The correct LG model is 20MP48AB (2017).
A few days back, a vertical line started blinking every 7 seconds, disappearing within 2 seconds.
Please help
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I removed the D-SUB connection and switched on the monitor, but it still shows the same problem. Therefore, there is an issue with the display.
Has anyone had a similar complaint, and is it repairable?
por
Adicionar um comentário
1 resposta
Solução escolhida
@invisiblebond that looks like a failing source driver. That was apart of the ribbon cables from the LCD to the driver board (part of the LCD display).You could check that ribbon for corrosion, small tears and small burns in that flex. Depending on what you find, IT may need a new panel or just some additional pressure on the ribbon. Once you have it apart, take a couple of pictures and post those with your Question. Hopefully we can provide more insight.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you for pointing out a workable solution. I hope the issue is related to the ribbon cable.
por
@invisiblebond I do too. I dislike having to replace anything just because of simple errors. Let us know what you find and how it works out.
por
Related Parts and Tools
Adicionar a sua resposta
Invisible será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 37
Ao todo: 402
