Ir para o conteúdo principal
The screen of laptop becomes black how to fix it
The screen of laptop becomes balck how to fix it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@rayyanbakht "The screen of laptop becomes balck" means to me that you have a display which then turns black. Correct? If so try this.
Once your screen goes black, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes of your desktop. Do this in a fairly dark room.
If you do see your desktop, then it is your backlight that has failed. If not, then it could be a GPU issue. Connect an external monitor and see if that turn black as well. If so, it's most likely your GPU.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rayyan Bakht será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 172
