Ir para o conteúdo principal
Released in May 2018, the Huawei Y6 has a 5'7 screen with a 720x1440 resolotion. It features dual sim and a Quad Core 1.4 GHz Cortex-A53 CPU.
Why is my phone too slow?
Esta é uma boa pergunta?
Pontuação 6
1 comentário
My pohone was very solow
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Hi @katlegoalex
Some things to try to resolve the problem:
Wipe the cache partition and check if the phone now works better.
Start the phone in safe mode and check.
If it works OK in safe mode then a downloaded app may be the cause of the problem. The trouble is to find out which one. You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall to see if it works OK or not. When it does then the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed on the phone and isn't one that was already installed on the phone when you first got it.
Esta resposta foi útil?
Pontuação 2
Gear Up For Future Repairs
Well free up space in your phone and update your phone to it latest software version it can help you in fixing the issue of your slow phone.
Pontuação 0
Could be a bunch of things honestly. Maybe too many apps running in the background, not enough storage, or your phone’s just getting a bit old. Try restarting it, clearing up some space, or checking for updates — that usually helps a bit.
Pontuação 0
Adicionar a sua resposta
Katlego Alex será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 34
Ao todo: 577
