Ir para o conteúdo principal
Manufacturer Part Number 100015685 Serial Number: G5KDCZ0670L5
17 Perguntas Visualizar todos
How do I get my SD card unstuck?
My SD card is stuck How do I remove it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
I suggest a magnifying glass - your phone may have this feature - and look at the card carefully to see where it is stuck. Small needle-nose pliers can be used to gently release and pull the card out.
Esta resposta foi útil?
Pontuação 1
Hi @maggie58
Try gently pushing the SD card in and then let it go.
It should spring back far enough for you to grab it and pull it out.
If you want to insert a new SD card (it only goes in one way so don't force it) push it in until it clicks into place.
Pontuação 1
Adicionar a sua resposta
maggie chastain será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 103
