Ir para o conteúdo principal
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
Snowy/fuzzy screen after ifixit battery replacement
Replaced the battery with ifixit battery kit. I was extra careful throughout the entire repair with absolutely no noticeable damage to anything internal. When the watch gets powered on it shows a snowy/fuzzy picture. Watch still works and seems like touch works. Any answers as to what could be the issue?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Did you use a solvent trying to take the display off? I’m suspecting that it got between the crystal and the display fogging it
If the display is noisy (snow) that is a bad cable connection
Post a picture so we can get a better idea what you are facing.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I didn't use any solvents. I used ifixit's iopener to open the watch. I'll have to try to check the cables but nothing looks damaged from what I can see. I unfortunately can not take any pictures for a while due to not being around the watch. Thanks for the advice.
por
Pergunta mais útil
Double check all connections are fully seated. Even a mm out can cause issues.
Pontuação 1
2 comentários:
I checked them a few times, feels like they were seated in all the way, I'll have to try again some more. I guess. Thanks
por
@malston make sure the contacts on the ribbons are clean as they're obviously making contact as you have an image. Is there any chance you might of pulled one of the ribbons?
por
Adicionar a sua resposta
Marc alston será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 141
