Ir para o conteúdo principal
The Intellivision is a video game console released by Mattel in 1979.
Help with my Intellivision
I just recently got a Intellivision that was assumed working when I got it for $15 and when I got home to test it, it didn't work. It appears to be sending a signal to the TV, but it wasn't sending a picture. It is supposed to be connected to a VCR but it uses coax in an RCA connector plug.
UPDATE
Replacedthe capacitors and guess what. Nothing. Should I redo the joints? Used the Exact same capacitors.
Esta é uma boa pergunta?
Pontuação 1
6 comentários
Did I spell Intellivision correctly?
por
hello, you absolutely spelled it right ;) anyhow, have you tried to connect it through a VCR?
por
Yes, I did connect it to a VCR (who has those anymore? I guess I do.) I got the results that are noted above.
por
I am sure you watched the polarity of the caps when you soldered them in? Any thing else on the PSU that looks out of whack? you said before that the voltage was not matching. what do you get now?
por
The polarity is correct I didn't replace the voltage regulator though, should I replace that?
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Solução escolhida
Hello, check this from the service manual:
1. Connect the Master Component to TV, plug in power cord, set the Antenna Switch Box to TV and determine that the set works correctly on broadcast stations.
So, make sure that your switch box is set properly.
UPDATE
Here is a link to an online service manual that can further help you narrow things down.
Esta resposta foi útil?
Pontuação 3
14 comentários:
Sorry, I didn't know what a switch box was. Do you know where I can get one?
por
This will explain some more http://www.atariage.com/howto/connect.ht... and your best bet would be to try Google to get a switch box. They are still around but hard to find. Not knowing where you are, you might want to try Radio shack as well.
por
Thanks, I found it on AtariAge, and the adaptor is at RadioShack for $4.19. I will buy it tommorow and see how it works and tell you guys. Thanks oldturkey03!
por
Sounds great, good luck to you. Hope it works out and let us know....
por
Unfortunately, it didn't work out. But, I've found the culprit! It's the power supply. It was in the Intellivsion Service Manual. But, does anyone know where I can get one of these. I don't want to have to rebuild it(even though I know soldering pretty well).
por
Exibir mais 9 comentários
Adicionar a sua resposta
thelectronicnub será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 5,682
