Ir para o conteúdo principal
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
How old is Kenmore Washing Machine 110 Serial Number C12622624?
How old is my Kenmore Washing Machine Model 110, 20022011, Serial Number C12622624? The drum is not sitting straight. I am not sure it is better to fix it or get a new washing machine?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
According to this website the washer was most likely manufactured in 2011.
If the drum is not sitting straight and it wobbles when in use it may be a problem with the suspension rods part # W10780048 that hold the tub in place. (example only to show what part looks like and possible cost - there are other suppliers.
Here's a link to a parts supplier that may help.
If you find the problem with the washer and it is something else, use the supplier linked to find the part number for the part. Then search online using the part number only to find suppliers that suit you best.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Chris V será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 28
Ao todo: 870
