Ir para o conteúdo principal
The DJI Air 2S is a small folding consumer drone with a 1-inch sensor camera.It was released April 2021 by DJI.
My remote not connecting to the drone
Hi
I really need your help hare, i had incident with my drone DJI 2s and the arm broke, i change the arm with new one but unfortunately it can't be contacted to my remote i try to change the remote but still not connecting,
When o turn the drone its start normally and all light coolers blinking normally but can't contacted can you help me if this isshes its from the matherbord bord as i dont have any near by repair shop for DJI
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
Check if the drone's WiFi signal appears in the available WiFi network list on your mobile phone.
The drone operates on both the 2.4GHz and 5.8GHz wireless bands which is the same as most phone WiFi bands.
It may have a name that you don't know so if you turn off the drone and it disappears from the phone's WiFi list and then reappears when you turn on the drone again you know that is it.
If you can't detect the drone by using a phone then most probably it is not transmitting. You may have to check the antenna connection in the drone.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Abdulmajeed será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 214
