Home button ribbon flex
Hi all
In need of some help, I stupidly pulled apart the flex on the home button on this iPad 5th generation A1822, and need this to work again, can this be repaired, pictures attached.
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Hi all
Looks like you ripped the cable. Luckily you can use the iPad 5 Wi-Fi Home Button Assembly Replacement guide and replace it. Since this is an iPad with a physical button replacing it will only loose Touch ID but the regular home button functionality remains.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 65
