Ir para o conteúdo principal
Kawai CS9 digital piano Power
I have a Kawai CS9 digital piano which would not power on yesterday.
This was due to a blown internal fuse on the power board. I have replaced this fuse and the piano now plays fine, but unfortunately it will now not turn off!
After pressing the power button to switch the piano off, all I can hear is a loud low buzzing noise and the power light remains on. I have to turn it off at the mains to turn it off.
Any ideas?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi @jamesrdixon
There's always a reason why a fuse blows so whatever caused it to happen may have damaged something else as well or it got damaged in the process.
Vague answer I know but without the schematic it would be hard to find out without testing each component individually, unless there's obvious visible component damage on the board.
I couldn't find a free download online but here's a link to the service manual that may help.
Service manuals usually have schematic diagrams and a parts list. If you're lucky it may also have troubleshooting flowcharts as well.
Given the cost of the manual it may save a lot of time by getting it.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for your reply. I did download the service manual yesterday and as you say I think I am going to have to test each component on the inlet board to identify what has failed.
por
Adicionar a sua resposta
James dixon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 353
