Ir para o conteúdo principal
On April 14, 2014, Nissan unveiled a third generation Murano at the New York Auto Show.
How do you check the transmission fluid?
There has to be a way to check my own transmission fluid on a 2015 Murano SV without taking it to the dealer or a mechanic.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@skweek1 dang that is a beast. Check on here under step 3
"The dipstick is not like the oil dipstick, there is no stick, so you won't be able to check the level.
To remove it, you will need a long skinny flat head screw driver. There is a tab on the dipstick, you need to insert the screwdriver to move the tap while pulling up on the dipstick."
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
E Thom será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 75
Ao todo: 2,112
