Ir para o conteúdo principal
replace LED backlight at Dell Latitude 5289
Hello :)
The touchscreen of my dell latitude stays dark. After troubleshooting it tourned out to be the LED backlight. Can I just change the backlight or do I have to chance the whole touchscreen? Until now I have very few experience in repairing electric devices. Answers in english and german are welcome.
Thank you very much!
Kind regards
Katharina
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @beuteltier
The backlights in the screen are LEDs and are a part of the screen assembly and cannot be individually replaced. The complete display assembly would need to be replaced.
Here is the service manual that will help you to replace the display assembly if that is what the trouble is.
It may not be the screen, it could also be a faulty lid sensor or a backlight power fuse or a loose eDP cable connection (video cable).
To try and test the lid sensor, connect an external monitor to the laptop so that you can navigate through the settings and change the lid switch setting to do nothing. Save the changes and restart the laptop and check
It may be better to purchase the schematics for the motherboard to help determine where the problem is first. (I couldn't find a free download - also verify that I've linked the correct motherboard i.e. Compal CAZ30/CAZ40 LA-E111P as printed on motherboard itself).
Esta resposta foi útil?
Pontuação 2
2 comentários:
Hi @jayeff,
thanks for your fast answer. I will check out all these things and tell how it tourned out.
por
@beuteltier
I updated my answer to include a possible lid switch check
Cheers
por
Related Parts and Tools
Shop all
Adicionar a sua resposta
Katharina será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 306
