How to replace charging port
The charging port is loose and the power brick does not charge the laptop, how can I replace the port on the MoBo?
Esta é uma boa pergunta?
Hi,
Here's the hardware maintenance manual for the laptop.
Go to p.92 to view the necessary pre-requisite steps and then the procedure to remove/replace the DC-In connector. If it is faulty it cannot be repaired, it needs to be replaced.
Search online for 04W6989 to find suppliers that suit you best.
Esta resposta foi útil?
Related Parts and Tools
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 447
