Ir para o conteúdo principal
O Lenovo ThinkPad L460 é um notebook empresarial de 14 polegadas lançado em janeiro de 2016. Possui uma construção durável, design preto fosco e um TrackPoint vermelho no meio do teclado. Pesa tipicamente cerca de 1,9 kg, apresenta um processador Intel Core de 6ª geração e recursos de confiabilidade. É adequado tanto para uso comercial quanto educacional.
Problem with screen or motherboad?
My lenovo T460 has no 3.3V and no other voltages on screen controller board (CON) except the 20V on the connector and in a big coil. Also no backlight and no picture. Is it possible to have fry anything in main motherboad ? (My hdmi output working normally with my external monitor).
Initially I changed the screen cable, because my screen was changing colors and making vertical shades with freezing picture, especially when the lid was moving.
Initially the problem seems to had be solved ,but after 5 min the problems return, so I opened the screen and begun probing on the CON for voltages and any defect cups and at that time the backlight and the picture was on, with the defects showing..
Now it's only a black screen.(with working hdmi output to TV)
The question is how do I know that I haven't done anything wrong with the motherboard, while I was probing the screen con board ? The 3.3V and other voltages are coming from the motherboard though the screen cable or from the lcd controller board?
Where could I have to start searching ?
I Appreciate your time
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Mine has no display but shows charging light and power light
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi @metachaos
Couldn't find a schematic for a T460 but found one for a T460s (Compal NM-A581 motherboard) which shows that the backlight power is supplied via fuse F6 on the motherboard and goes to pins 27 & 28 on the LCD connector.
If the fuse is blown it is a 3A_32V_ERBRD3R00X.
If there is no power on either side of the fuse, the power comes from Q1 (TPCF8002_2-3U1A)
If there is power on the pins then then backlight is turned on and off in the screen by a backlight enable signal sent on pin 18.
Here's the schematics that may help you further, (scroll down to the download link). Go to p.38 to see the pinout for the LCD cable connector.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Lord Chaos será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 36
Ao todo: 1,129
