Why does the charging light blinks?
The light for charging keeps on blinking unless i turn off the laptop, secondly, charging it can be difficult, sometimes it does not charge or stops charging
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
@leems it appears as if the light is blinking because your computer is not charging. Check your charger with a multimeter and see if that works as it should. The check the DC jack for your computer make sure it is clean and not in any way obstructed. If that is okay, replace the battery. Then re-evaluate.
Acer Aspire 3 A315-21-92FX Battery Replacement - iFixit Repair Guide
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 2,361
