Ir para o conteúdo principal
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
Adhesive inside display cut
Hi, unfortunately while changing the battery of my watch, I destroyed the bridge of the adhesive (with copper underneath) between the middle “island” and the right “island”. It should be connected like the left “island”. Hope someone understands and sees what I mean. Please see my photo.
Now, with the new battery, I cannot start the watch. The Apple symbol pops up for a few seconds, but nothing happens. Is this destroyed bridge the reason?
How can I repair the connection or get a spare part?
Thanks so much!
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Well, the battery was just ordered from ifixit. 😉
por
Adicionar um comentário
2 respostas
The copper adhesive strip is an EMI shield it doesn't effect the running on the watch. But the lifted edge could be pressing on the battery so I would use a jewelers burnisher to carefully press the edge down.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks so much for your quick answer.
What could be the reason that the watch is not starting?
The battery that I exchanged was bloated.
por
@oliver75 - Sadly, you really can only do swap out of the major parts like the display and the SIP if you are sure the battery is good.
por
Related Parts and Tools
Shop all
Pontuação 0
Adicionar a sua resposta
oliver será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 88
