Ir para o conteúdo principal
Fully portable sequencer and synthesizer from Teenage Engineering, which can also produce live visuals and control DMX equipment.
Where do I get replacement encoder dials?
Encoder dials don’t seem to be available and I’m missing two thanks to lending it out, please help
Update (09/12/2022)
3D file for replacement encoders with space for a 6mm DIAMETRIC magnet https://drive.google.com/file/d/1-O0g11s...
Esta é uma boa pergunta?
Pontuação 5
1 comentário
Hey dude, did you ever figure this out? I have the same issue and can't find out where to get a replacement. I've even tried buying a broken one on ebay to replace with but other people keep on out bidding me
por
Adicionar um comentário
2 respostas
Solução escolhida
I did, but there is a catch.. I ended up buying a 3d printer, modeling the encoder myself, printing it, figuring out that I needed a diametric magnet, and going through some troubleshooting.
So now i have 2 blue dials, but they work perfectly.
I'd be happy to make some more.
atom8oh insta
Esta resposta foi útil?
Pontuação 2
5 comentários:
Could I get the Stl. file?
I have the same problem.
por
Appreciate the file, what magnet dimensions did you use exactly? I'd guess by the file that it's 6mm x 1.5 mm but that does not appear to be a common find...
por
Would I be able to purchase some screen printed knobs off of one of you kind fellows?
por
Im keen just lost an encoder
por
Gear Up For Future Repairs
Shop all
I 3D printed a replacement but the magnet I used sends the encoder crazy so i cant use it. I might need to hget a bidirectional magnet :(
Pontuação 0
2 comentários:
You for sure need the right type of magnet. diametric magnets are what you need
por
I have the same issue, lost all 4 knobs in a car accident. Would I be able to buy some of the screen printed ones off of you please??????
por
Adicionar a sua resposta
semilogical será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 28
Ao todo: 872
