Ir para o conteúdo principal
Guias de reparo, informações de desmontagem e resolução de problemas para a 5ª geração do Apple iPad com 4G LTE, disponível com 32 ou 128 GB de armazenamento. Lançado em março de 2017. Identificado pelo número de modelo A1823. Possui tela Retina de 9,7" e processador A9 de 64 bits.
How to bypass MDM after restore
Company I work for is moving offices and scrapping all our tech gear. Snagged an iPad but after restore its MDM locked. Need help bypassing. iPad 5th gen. Lte enabled.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
It’s implemented on the Apple activation servers, the server knows this ipad belongs to the company and has MDM enforced during activation.
You can always talk to the IT department to release it from MDM, or you can replace the major chips to swap identity of this ipad, probably costs as much as the ipad itself.
Esta resposta foi útil?
Pontuação 1
3 comentários:
@tomchai I have a2485 with the same MDM problem. Do you know who can offer service or what chip needs to be removed or reprogrammed? Thank you
por Compartilhar
@fobby New motherboard, or full chip swap. Contact the previous company to have it removed. Any competent company has a procedure in place when this happens, or the provider (like Absolute SW) has means to fix it.
Ideally, the best approach once the device is so absurdly old that there's little to no market left (like the D series, or old E series) is to just disable the crap permanently (but DISCLOSE THE PERMANENT BLOCK IN THE LISTING IF YOU SELL). I should be able to decide if I want to seal my device's MDM capability fate, even permanently, not the provider -- regardless of who makes it, even if I need to call Apple to tell them I want this thing blocked from accepting MDM until I SAY SO.
por Compartilhar
I found a way to get the MacBook open and bypass the MDM to turn the SIP off in terminal. I’m now wondering will it eventually get locked again and should I get some type of bypass now to prevent that?
por Compartilhar
Pergunta mais útil
I am sure the company will remove it for you if you ask. Besides that it is there for good.
Pontuação 2
2 comentários:
Not true. MDM is not permanent. Easily bypassed by a.bat file and other ways (file types) I am sure. Shouldn’t say stuff unless you’re sure, sorta like a lie. Smh
por Compartilhar
@aaronperea16224 Maybe at the time of posting the .bat file was not available. You should look at the date of posting. And maybe you should explain exactly how you bypass it.
por Compartilhar
The MDM can be bypassed on my 6th gen iPad (9.7). I used a .bat file I downloaded from a YouTube link. Just search for MDM bypass iPad rob. The content creators name is rob something, you won’t miss it. Promise. It’s all FREE AS WELL. TOOL USED is called 3utools, & I have used it for years now. No viruses or bs money asking bull. I swear. Your all welcome:)
Pontuação 0
1 comentário:
Until you restore it and then it comes back being tied to the S/N...
por Compartilhar
Adicionar a sua resposta
mjblaich será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 48
Últimos 30 dias: 184
Ao todo: 2,418
