Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Help find J9001 LVDS connector from A1181
Please help identify (Brand, part no) LVDS connector marked J9001 on K36 MLB logic board of Macbook A1181
It has 22 visible pins, although on schematics there are 26 pins (4 are casing soldered to GND).
Thanks a lot!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
The part is only listed as S-050162B F-RT-SM on the schematic. I was unable to locate it via Google.
I doubt you’ll find the logic board connector as a spare on its own. The best I can suggest is locating a junker to acquire the part. That then gets into what you can find and the costs.
Depending on which model you have you might want to just swap out the logic board as this is not an easy connector to desolder.
Esta resposta foi útil?
Pontuação 0
5 comentários:
Thanks, but i wanted to develop new device with this connector, so i need to get them fresh somewhere.
por
@nielsbor - While I commend your efforts to re-use parts.
This series MacBook display uses CFL's for its backlight logic so it also has a power inverter which would also need power besides the LCD panels logic. I'm sure the CFL tubes and inverter have worn-out given the systems age (dim or discolored images).
Also keep in mind electronics has transitioned from LVDS signaling to eDP (iDP) signaling for displays as well.
por
@danj This very macbook has pretty alive backlight. I connected backlight connector to the same adapter. It has +12, +5, GND, PWM. So it works
por
@danj ok but i dont need it at the moment
por
Adicionar a sua resposta
Niels Bor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 105
