Ir para o conteúdo principal
Lenovo's 15.6-inch display laptop introduced in 2020 with AMD Ryzen processors. Machine type (MT) 20NF
How can I replace the broken screen
Lenovo 20NF-0000GE
Something fell on the top of the laptop and broke the display, now I want to replace it but I don’t know how to take the Display-assembly apart and don’t want to break something.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here’s the hardware maintenance manual for the laptop.
Go to p.84 to view the necessary pre-requisite steps and then the procedure to remove the LCD panel.
Here’s a link to the parts for the laptop. Click on Select Commodity > LCD panels (5) to find the part numbers. Be aware that there are different types of panels i.e. FHD and HD. Sometimes the part number can be found on the back of the LCD panel itself if you wish to verify that you’re ordering the correct one.
Search online using the part number only to find suppliers that suit you best.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Julian Volgmann será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 393
