Ir para o conteúdo principal
The Frontier was introduced in 1997 for the 1998 model year as a replacement for the aging 1986–1997 Nissan Hardbody Truck.
9 Perguntas Visualizar todos
1998 Frontier wont stay running
when I push the gas pedal, it dies!!..seems like something is clogged up
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Check your fuel filter. Probably needs replaced. If that doesn't solve it check fuel pressures to see if your fuel pump is going bad. It sounds like it can't get enough fuel when calling for more.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thank you!..I changed the fuel filter which was a 16 min job, and I’m a girl…so it was FUN!!..and that worked!.the truck had been sitting for awhile, and the gas was old and turned to goo,…so I put some fuel stabilizer and a new filter and it fired right up!!…yay!!..if I have anymore questions I’ll give ya hollar!…hehe
por
If it has been sitting a long time, I would highly recommend emptying the tank and filling with new. Use a good fuel treatment to make sure everything is cleaned of varnish from sitting fuel. Fuel filters aren't fun, but they aren't as bad as some things. Even my old chevy isn't horrible. Isn't easy but not horrible.
por
Adicionar a sua resposta
Tudi Goins será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 1,146
