Schematics for the tristar area - Anyone can help?
I've got this iPad with a charging problem and I think it isn't the tristar itself. According to the “Diode Mode Mesurements”. from the wiki page, I figured out that there is only an open line from the charging port. Or has this line something to do with the battery itself? Without any schematics or boardview I can’t get any further. Before changing the tristar itself I want to be shure that nothing else is faulty. Any help will be highly appreciated!
Esta é uma boa pergunta?
2 comentários
Swap your probes around and measure. “Black probe on ground”
por Chris Stables
@imicrosoldering Thank you for your reply! What readings should I get there? Or should I mesure the volts when plugged in?
por Adrian
