Ir para o conteúdo principal
This is the upgraded version to the P75-A7200, with the only difference being a pre-installed 8.1 OS from windows on the newer device, rather than 8.0.
7 Perguntas Visualizar todos
How do I replace the battery plug in slot?
The laptop is old and it needs a couple of new parts in it, one of which being the square piece you plug the charger into. The piece is exposed outside of the case and I’m wondering really how to fix it.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi @duo01,
You need to remove the battery from the laptop and then open the laptop and remove / replace the DC-In jack cable (supplier example only to show part and cost).
Here’s the iFixit Toshiba Satellite P75-A7100 guides that may help
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
duo01 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 61
