Ir para o conteúdo principal
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
What do I do with Adhesive Gasket
I have an apple watch 3 series I’m not sure what to do with this piece { Series 3 GPS) Force Touch Sensor Adhesive Gasket } I replaced my screen and the seal and it works great , but my screen is a little loose on one side .Is this what this piece is for ? What would it do to the seal if I had to take the screen off again ?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
This question was migrated from https://meta.ifixit.com/Answers.
por
Adicionar um comentário
1 resposta
Previous versions of the Apple Watch (including the 3 had a feature called force touch, where pressing on the screen with light force would show extra options. If you need that functionality (which you probably do) you will have to open the screen back up, which will most likely break the seal. You should follow this guide, as well as the guide linked at the bottom of the page in the Conclusion section.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Patricia Dickerson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 85
