Ir para o conteúdo principal
Briggs & Stratton 190cc Model 120000 Quantum 675 Series Lawn Mower Engine. Released February 2011. For Toro 6.75 ft-lb torque Lawn Mower.
20 Perguntas Visualizar todos
Where is the oil drain
Where is the oil drain on my Briggs & Stratton motor 158cc 5.50
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Edward Bois we will need an engine number or model number for this.
por
Adicionar um comentário
1 resposta
Some engines will have an oil drain plug located on the bottom that looks like this:
But, some oil drain plugs will be covered by the housing, in which case, even the manufacturer says you can tip the engine over and drain it out of the fill tube.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Seize tool for oil drain plug
por
@azharmdidris make and model for your engine?
por
Adicionar a sua resposta
Edward Bois será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 38
Ao todo: 738
