Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Lid makes a popping sound when opened
The rear left side of the lid pinches against the rear left side of the top case causing a pop or clicking sound when the lid is opened. After looking through your 41 Step-by-step Guides I have this question. Is this a Left Hinge replacement or can this be adjusted in some way? The top is out of alignment about 1/16 of an inch to the right when closed.
MacBook 2.1 (5HS)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
OK, changed the left hinge and that seems to have worked. Cheers!
Esta resposta foi útil?
Pontuação 1
1 comentário:
Great--now would you please accept your answer so the question may be archived. Thanks.
por
Adicionar a sua resposta
Joe Gordon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 979
