Ir para o conteúdo principal
Repair guides and support for all household mechanical fans including ceiling, box, tower, and stand fans.
Box fan makes zingzing sound
My Robeson box fan stopped working, meaning I could hear the motor hum but the blades did not rotate. I removed the blade assembly, cleaned out the dust and oiled the motor. I tested the fan without attaching the blades. The motor seemed to work. After I put the blades back on again, I hear a zing-zing sound. How can I fix this?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi @anupm12
If you hear the motor hum and it does not spin well, I suggest you to check on the fan capacitor first. It should not crack / bloat or leak.
por
Augustine, after the cleaning and oiling the motor (with blades removed) does spin properly with no strange noises. When the blades are installed, the motor still spins but I hear a constant zing-zing sound. The capacitor is not cracked, bloated nor leaking.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @anupm12
With the blades on, when manually spinning them, looking from side on i.e. not from the back or the front, are they turning in a fixed plane or wobbling about due to a bent rotor shaft or faulty bearing that is only noticeable with the weight of the blades on it?
Esta resposta foi útil?
Pontuação 1
7 comentários:
Jayeff, I don't detect any wobbling.
por
@anupm12
Does it make this noise when the fan is outside of the protective cage or only when installed inside it?
por
The motor and blades remain within the box (protective cage). I did remove the front and the back grills in order to make repairs.
por
@anupm12
So the blades aren't hitting the box at all (side/front) as they turn?
Are the blades all at the same angle away from the centre point?Just wondering if one were at a different angle (twist?) that it may cause the air to make a different sound
por
The blades are not hitting anything. One of the blades is twisted when compared to the other two. However the zingzing sound is metallic and not a swish of the air sound.
por
Exibir mais 2 comentários
Adicionar a sua resposta
Anup será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 423
