Ir para o conteúdo principal
The Toyota Prius is a hybrid electric car designed by Toyota. The third generation, sold from 2009 to 2015, introduced a new body design with a lower coefficient of drag.
remove inside panel on rear hatch lid,
how do remove it? The bolts to hold the plate are shot and I need to replace
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here’s the 2009-2015 Toyota Prius Repair Manual (RM1290U) + Electrical Wiring Diagram.
Scroll down to Vehicle Exterior and click on Door and Hatch. When it has opened in the webpage, go to p.16/136 (.pdf page number in document header bar, as there is no page numbering in the manual) to find the section dealing with the Back Door trim assembly removal procedure.
To make the document easier to use, download it to your computer by using the Download link on the top right side of the document header bar.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks, never would have found it w/o yousr help
por
Adicionar a sua resposta
cjohnson00911 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 1,648
