Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
MacBook won’t turn on
I purchased a MacBook A1181 but it shows no sign of life, when I press the power button the LED of the stop state lights up and goes off immediately, sometimes when I insert the power cable the LED turns dim green. I tried to change the power supply but the problem is the same, I also changed the ram but nothing. What could it be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Let’s try for a spontaneous re-boot. Disconnect the mag-safe, Disconnect the battery from the logic board. Prterss and hold the power on button for 10 seconds. Now reconnect the battery, then connect the mag-safe. It should reboot on its own if it is working.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Still nothing
por
Return this defect machine.
por
Adicionar a sua resposta
Sergio Catania será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 90
