Ir para o conteúdo principal
Model numbers JSN-L21 and JSN-L42.
32 Perguntas Visualizar todos
Phone not responding, no charge indicator light.
My smartphone stopped working after i had charged it to 100% capacity overnight. The next morning i was still able to use the phone, but i noticed it stopped working after class. The battery is still fine (i checked it with a multimeter). Maybe a broken powerswich? There is no red indicator light or a charging iconon the screen (Was just replaced) while trying to charge the smartphone. Maybe a bad charging circuit?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Paul Streck  sure could be a failed charging circuit. The very first thing that you do want to rule out is the battery. You cannot check a battery with a multimeter since it may show proper voltage but can fail under load. Replace the battery and re-evaluate.
Of course, you also want to make sure that your charger works properly as well as your charging cable.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I am 90% shure that the battery is not the problem, because the red charging indicator light is not lighting up. The light shouldn't be that much of a load to cause battery voltage sag. My charger and cable are working properly. I personaly think that there is a problem with the mainboard power delivery since basic things like the charging indicator are not lighting up.
por
If you know how to open the phone, try unplugging the battery and pressing the power button for 1 minute to drain any excess power in the device that may be causing this.
Pontuação 0
1 comentário:
Tried, but didn't fix it :(
por
I have slept at night by keeping phone beside me and when I saw morning it didn't work from last 1 month
Pontuação 0
Adicionar a sua resposta
Paul Streck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 38
Duração total: 1,485
