Ir para o conteúdo principal
The 5th generation of the Moto E Play smartphones, released in July 2018. Model numbers XT1921
Replacement screen not as bright
I just replace the screen ony Moto e5 cruise and it's not as bright as the old one was. Can I fix this or does it just have to do with the quality of screen i.got?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
@auz5280 the reason for that is most likely the quality of the display you purchased. You will always find that there is a wide variation of brightness etc. with replacement screens.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Is there a brand you would recommend? Because this one is really dim. I could barely see it when I went outside yesterday to go to work. And it was cloudy.
por
Adicionar a sua resposta
Austin Hargove será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Ao todo: 150
