Random off balance spinning
Top load washer will randomly start making load knocking noise during middle of spin cycle as if the clothes were not balanced.
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Sounds like a counter balance spring (least that is where I would start). Luckily Kenmore/whirlpool are pretty easy to pop open if it is an older model.
Pop the shell off and take a look at the bottom back end of the tub see if the spring is broke/not connected. If it is broken get a replacement but sometimes the hole the hook is in will be broken. Just drill a new hole in the frame. and re-connect.
There are videos if you need a play by play.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 144
