Ir para o conteúdo principal
Repair guides and support for Kenmore washing machines.
Random off balance spinning
Top load washer will randomly start making load knocking noise during middle of spin cycle as if the clothes were not balanced.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sounds like a counter balance spring (least that is where I would start). Luckily Kenmore/whirlpool are pretty easy to pop open if it is an older model.
Pop the shell off and take a look at the bottom back end of the tub see if the spring is broke/not connected. If it is broken get a replacement but sometimes the hole the hook is in will be broken. Just drill a new hole in the frame. and re-connect.
There are videos if you need a play by play.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Brian Singletary será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 207
