Ir para o conteúdo principal
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
Why is my controller not charging?
Recently, which is a little over a month ago, I have bought a new controller for my PS4. It was working great when out of the blue it randomly stopped charging. When I say charging I mean that it doesn't charge in the PS4 nor a wall outlet like it could before. I also switched different cords and it still doesnt charge. Can anyone offer any help/guidance?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Hi,
Have you checked if the Micro-USB port isn't broken? If you bought it as new, you should be able to return is as it is under warranty.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yes I have this problem too the difference is I’m trynna fix that but I’m stuck on this one screw it’s not Philip screw it’s like they used a different screw on one of the holes and left every other one Philip my controller won’t charge and I’m trynna replace the usb wit one that works perfectly fine
por
Gear Up For Future Repairs
Shop all
Like what @gotowiec27 said, if you bought new, you should be able to warranty the controller. Otherwise if you want to tackle the troubleshooting yourself, try getting some contact cleaner first. Squirt a little into the charging port and insert the charging cable a couple times to work in the cleaner. Sometimes a little gunk or buildup can disrupt the connection. DeoxIT:
DeoxIT® Connector Cleaning Kit
If that doesn’t work, try your hand at this guid to replace the charging part assembly altogether:
DualShock 4 Charging Port Replacement
@yungloy , your link is 404’d so I can’t see the screw you are referencing.
Imagem de Clean and deoxidize electrical contact surfaces in cell phones and other electronics.
Produto
$6.99
Pontuação 0
3 comentários:
Can u look at that and help me what screw driver I need to open my controller
por
@yungloy your link still gives 404 message
por
How do I send pictures of it to you
por
Adicionar a sua resposta
Dominiq Jones será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 397
