How do I add a ssd into it?
I want an SSD for it to be faster how do I add one?
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
You will need a SATA to USB cable and some cloning software.
EaseUS Todo Backup Free is one example. There are others.
The below link will show you how to physically replace the drive.
Esta resposta foi útil?
Puzzled that when i view the instructions there is NO hard drive when it is opened then it APPEARS suddenly. When I opened mine there was NO HARDDRIVE!!! After more research I discovered that the SSD is actually chips on a board that are soldered DIRECTLY onto the motherboard and CANNOT BE UPGRADED!!!
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 187
