Ir para o conteúdo principal
Toshiba Satellite CL15t-B1204X Hard Drive Replacement
Royce Alexander Porter
Royce Alexander Porter e 3 outros colaboradores
Última atualização em December 30, 2022
5 minutos
Moderada
Fotos de ação
Precisa de melhores imagens
Melhor Introdução
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Toshiba Satellite CL15t-B1204X Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 2, imagem 1 %32
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 3, imagem 1 %32
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 5, imagem 1 %32
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 6, imagem 1 %32
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32
    • Carefully unplug the cable near the USB on the left side.
  8. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 8, imagem 1 %32
    • Delicately pull on the hard drive and the case it's in to unplug it from the motherboard.
  9. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 9, imagem 1 %32
    • Peal the rubber casing around the hard drive off to completely remove the drive.
Conclusão
4 outras pessoas executaram este guia.
5 comentários
What kind of joke is this?! Spent an hour taking my toshiba apart and THERE IS NO DRIVE IN HERE!!!! WTF
Hammerjockey Radios - Responder
Do we change ssd hearddisk 240gb with same ram
Kamal Badiyani - Responder
I agree with Hammerjockey Radios, you guys should be more clear. there’s no drive on this model.
Ernesto Filho - Responder
I started to think the drive was missing b/c my model is just -1204, not the 1204X version. But then I looked again at the pics above. There is NO DRIVE in their pics either! Not until steps 7-8 where you can see they layed one in there. Steps 3,4,5&6... There Is NO drive so why would you be taking the battery out? Even if there WAS a drive in this model, unnecessary manipulation of a lithium battery is not a wise move.
NDR - Responder
Puzzled that when i view the instructions there is NO hard drive when it is opened then it APPEARS suddenly. When I opened mine there was NO HARDDRIVE!!! After more research I discovered that the SSD is actually chips on a board that are soldered DIRECTLY onto the motherboard and CANNOT BE UPGRADED!!! My model is cl15t-b1204x. My crying begins NOW. Love my laptop but with updated on win 10 there is NO MORE ROOM not even for a single APPLICATION! Going to try to install win 7
Rick C - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 25
Duração total: 3,074
