Ir para o conteúdo principal
Toshiba Satellite CL15t-B1204X Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite CL15t-B1204X Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 2, imagem 1 %32
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 3, imagem 1 %32
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 5, imagem 1 %32
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 6, imagem 1 %32
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32
    • Carefully unplug the cable near the USB on the left side.
  8. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 8, imagem 1 %32
    • Delicately pull on the hard drive and the case it's in to unplug it from the motherboard.
  9. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: passo 9, imagem 1 %32
    • Peal the rubber casing around the hard drive off to completely remove the drive.
Conclusão
4 outras pessoas executaram este guia.
5Comentários do guia
What kind of joke is this?! Spent an hour taking my toshiba apart and THERE IS NO DRIVE IN HERE!!!! WTF
Hammerjockey Radios - Responder
Do we change ssd hearddisk 240gb with same ram
Kamal Badiyani - Responder
I agree with Hammerjockey Radios, you guys should be more clear. there’s no drive on this model.
Ernesto Filho - Responder
I started to think the drive was missing b/c my model is just -1204, not the 1204X version. But then I looked again at the pics above. There is NO DRIVE in their pics either! Not until steps 7-8 where you can see they layed one in there. Steps 3,4,5&6... There Is NO drive so why would you be taking the battery out? Even if there WAS a drive in this model, unnecessary manipulation of a lithium battery is not a wise move.
NDR - Responder
Puzzled that when i view the instructions there is NO hard drive when it is opened then it APPEARS suddenly. When I opened mine there was NO HARDDRIVE!!! After more research I discovered that the SSD is actually chips on a board that are soldered DIRECTLY onto the motherboard and CANNOT BE UPGRADED!!! My model is cl15t-b1204x. My crying begins NOW. Love my laptop but with updated on win 10 there is NO MORE ROOM not even for a single APPLICATION! Going to try to install win 7
Rick C - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 40
Ao todo: 3,093
