Ir para o conteúdo principal
Guias de reparo e informações sobre desmontagem de laptops de todos os formatos, tamanhos e cores.
Pergunta encerrada
Issue In Laptop Battery?
Are You also Facing Issue In Laptop Battery?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
  •     Remove the battery and check the contact points to make sure they are not damaged.
  •     Unplug all USB devices from the laptop. ...
  •     Unplug the AC power cable.
  •     Insert the battery into the battery compartment on the bottom of the Laptop
  •     If you have a second battery for your computer, replace the original battery with the second battery and check Maybe the battery has gone When your battery goes, replace it with a new one.
An expert can talk you through your options, helping you arrive at exactly the right kinds of decisions for your needs.
Visit [http:// https://uaetechnician.ae/laptop-repair-s...|Laptop Repair Dubai] More Information
Esta resposta foi útil?
Pontuação 0
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 34
