Installing SSD on Acer Aspire E5-511p-C6US
Is it possible to get a detailed guide on adding an SSD to my Acer Aspire E5-511p-C6US
Esta é uma boa pergunta?
The best thing is to watch YouTube videos.
Are you having trouble with something specific? Installing the ssd is straightforward.
You generally use software to clone the hard drive. Sandisk for example has software that does this for you. If you hook up the new hard drive externally with an adapter,and use the software,it will clone the internal hard drive to the hard drive you have hooked up. Then you can simply swap them. It should “just work”.
Esta resposta foi útil?
Related Parts and Tools
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 149
Hi,
Are you adding a SSD by replacing the DVD drive or just changing the HDD for a SSD?
por jayeff
