Should I change the force touch sensor?
While opening my watch and removing the broken display screen, an edge of the force touch sensor was lifted and isn‘t sticking to the case anymore. The part is working and not damaged but as said, the edge is not sticking to the case. I don‘t know if the new display might sit loose on this edge.
Would you recommend replacing it as well?
Esta é uma boa pergunta?
1 comentário
Thanks, that made it clear. Will replace it and in addition replace the bat to have a new one inside
por Aug
