Ir para o conteúdo principal
The Toshiba Satellite A215-S7425 (PSAFGU-30J002) is designed for an exceptional multimedia experience with its wireless LAN and multi-DVD reader.
6 Perguntas Visualizar todos
Crash on boot up
It keeps either crashing and restarting or showing the screen in the image attached what is going on any ideas?
I also tried to install a new version of windows thinking the old one is bad but it crashed doing that too...
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Is it possible that you could translate into English what the error on the screen is saying
Thanks
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@taylor13 try and get into your BIOS (Basic Input Output System) and see if you can read the writing in that. If so then you may need to consider setting the boot order to USB or optical drive. Once that is done restart your computer with a Live CD Linux distro or USB version. See if that displays properly. try an external monitor as well and see what you get. This could be an error with your motherboard as well as a monitor error as well as your OS. Time to narrow it down so let us know what you find out.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Adam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 106
