Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Computer Battery display not accurate?
My Macbook's display reads that my battery is at 85%, and then goes to "Not Charging." According to the led readout on the battery, its full.
How do I reset, for lack of a better word, the percentage readout coming from my macbook in order to accurately represent the charge on my battery?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Download and run Coconut Battery and run it to see what the status is and please let us know: http://www.coconut-flavour.com/coconutba...
Esta resposta foi útil?
Pontuação 4
6 comentários:
Battery loadcycles is at 215. The current Battery Capacity is 4648mAh, the current charge (at a "Not Charging" state) is 3938 mAh.
por
Please tell me why someone downvoted this question
por
I'm not sure...
por
If you run it all the way down and then recharge it will reset it.
por
Do you mean I need to calibrate the battery? I have done this. I made sure it was as full charged as possible, then ran the battery down until the computer went to sleep, waited for 5+ hours, then fully charged it again. It has remained in this same state.
por
Exibir mais 1 comentário
Adicionar a sua resposta
Ben será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 457
